D
Deleted member 174758
Maybe the way to think about this is to consider the unsupported length of a joint. On standard 400mm centres with 50mm thick joists the unsupported length of joint between joists is about 350mm. On your 350mm centres it will be about 300mm. 18mm plywood or P5 chipboard under domestic loading won't really deflect a great deal over such a short span especially as the material is rigidly fixed into both joists (whereas in a shop or office building point loadings may be far higher which explains why we go to greater lengths to add strength in the long joints). The unsupported end of a board will tend to move and droop under loading and whilst you might get away with your solid strutting supporting it, you might find that in service it creaks or cracks under variable loadings as two unsupported ends move independently. Personally I'd rather not take the chance because once your UFH and everything else is down it'll be a helluva task to dig things up to sort out a creaking floor
Should be. Bear in mind that you'll still need to trim the ends off so that they land on a joist because if your non-standard joist spacings (350mm centres)Is this suitable? I find it easier to source materials from big retailers.
https://www.selcobw.com/products/ti...ood/structural-plywood-ce2-2440-x-1220-x-18mm
