Hi
I purchased a house nearly 5 years ago, and it was in good decorative order (and largely, still is), so much so that I have not decorated since I moved in.
Over the past 4 and a half years cracks have appeared in the plastered walls. The house is a 1930s semi. Ceilings are lath & plaster and walls are plaster straight onto brick for the external walls, or some kind of block for internal walls.
There are no cracks in the external walls outside, so I assume these cracks are a result of temperature changes over the seasons. I have filled a few cracks with polyfilla, but the crack just re-appears in the polyfilla after a few months. What can I do to get rid of these cracks and prevent then from re-appearing?
Any advice would be appreciated. Thanks.
