Hi
I have just had a very bad leak in utility room floor which was found by a very expensive leak detection service. They also repaired the pipe with a new 8inch section of copper.
There was bad corrosion on the outside of the mains pipe even though it was wrapped in insulation.
I couldn't work out what else was wrapped round it because it was so wet it fell to pieces!
The corrosion seems to be limited to just in a doorway.
There is a hot water pipe next to the leaky one that looks just as bad so I'm thinking I will have to replace that as well.
All the pipes in the house are about 32years old.
How should I protect the new pipes please?
thanks
Mike
thanks
Mike
