socket earth connections
16 Jun 2006
London
Hi
Currently decorating a house.
I undid the brand new chrome socket face plate screws so that I could back fill.
None of the the face plates have an earth cable running back to the metal boxes. Surely That os wrong?
If one of the lugs on the Back box is permanent with no movement rather than slightly adjustable there's nothing completely wrong as such but it's better practice to run an Earth to link the socket to the back box.
When the Socket is screwed into the back box the Screw makes the earth connection, most electricians would run the small tail.
I undid the brand new chrome socket face plate screws so that I could back fill. ... None of the the face plates have an earth cable running back to the metal boxes. Surely That os wrong?
There presumably is an earth wire going to the socket(s) themselves? If so, then that will earth the face plate and the face plate screws will, in turn, earth the back box. However, many people would also run an earth wire from face plate to back box.
A bigger problem arises with metal light switches, since the switch itself does not have an earth connection. In that case, it is desirable to have an earth wire going from the face plate earth terminal, although people have been known to earth just the back box and rely on face plate screws to earth the face plate.
What do you mean?
Metal light switches not having an earth connection -
and then -
Metal light switches not having an earth connection - and then - In that case, it is desirable to have an earth wire going from the face plate earth terminal,
Ah, I see.
A correct reference to what I wrote would recognise that what I wrote was actually ...
... since the switch itself does not have an earth connection ... (and "the switch itself" means just the switch, not switch+face plate)
In other words, unlike a socket, a switch ("itself") does not have any earth connection, but it's face plate will (if metal) have an earth terminal. Failure to make an earth connection to that face plate terminal therefore results in an unearthed face plate, even when "the switch itself" is wired correctly.
That comment was to contrast the situation of a light switch with that of a socket. In the case of a socket, if the "socket itself" is wired correctly (including the CPC), then its face place (if metal) will automatically get earthed.
Is that clearer?
Thanks.
I didn't realise that the earth is actually connected to the faceplate. BTW the electrician did run earth leads to the light switch back boxes. I shall screw the face plates back on later today.
