Tamper on Pyronix outside bell
18 Oct 2017
If I took the cover off with the alarm not armed and in engineer mode would this tamper activate?
Cheers
It wouldn't set the panel sounder off but will still sound the bell as soon as you lift the cover unless the engineers hold off as been wired.
Engineers hold off hasnt been wired but I changed the cover todays and It didn’t go off, everything works as inteded except that
Sounds like the tamper switch as been wired out or jammed/broken, (if it still works normally with bell test)
So things to check would be
Tamper return to T inside alarm panel
The - to T link is fine
And the rear tamper is pused against the wall.
Would that be correct?
It's more than likely just a faulty tamper switch, try pulling it away from the wall it should be on a pivot making sure it still can move. Also check that the wire from the switch going the bell pcb hasn't been cut and twisted together.
Thanks will have a look during the weekend, if it is faulty would I need a new bell box? Its only a week old
You will just need a new internal module they just clip in/out with one small screw.
That's if you are really that bothered about a tamper on the bell box, how high is it? do you need ladders to get to it?
What are the real chances of someone turning up with ladders knowing that the tramper doesn't work opening it up and disconnecting the siren?
Yeah I will do a few checks to rule out possible causes that you have mentioned, I actually bought the delta plus module due to the interal lighting it goes off during the night , so i rather have the tamper,
Highly unlikely as its at the top of a two storey house, you need ladders but I think I will try and figure it out and worst comes to worst leave it
Update -
When taking the cover it, it does sound.
But when I try pulling it the pivot seems to be already stuck in or doesnt move ( my brothers as soon as you pull it alarms)
Now how do i sort this without the bell off?
Its probably jammed on the back pin on the rear plate, when you clip the internal module into the back plate you need to lift the tamper switch up when you push the module downwards.
Yeah that’s probably were I have went wrong,
How can i deactive the bell when taking cover off?
Easiest way is just unplug the sounder on the bell box itself the strobe will still flash.
