I am currently building a 3m X 3m rear extension (-permitted development) with 2 types of Aircrete blocks - 215mm (x 440L x 215H) and 140mm (x 440L x 215H). At one corner where these blocks meet, I just noticed that the 140mm blocks are vertically out of square by about 8mm at the widest point.
This bad corner has already reached its maximum Ht & W (1000mm x 550mm) made up of only 4.5 block columns containing only 1.5 blocks in each row horizontally because it has a window opening (1m W x 1.2m H) and will also be a sloped wall ending at maximum height (1.1m) when a bond beam(100mm H)is added.
I don't want to knock them down as they are bonded to the perpendicular 3m (21mmm) wall- too much mess /may require wall starter kit -bad at corners. As they are aircrete, can I build up the 8mm difference using special fibrous cement like Sika products ?. Also any suggestions of the right Sika mortar etc- overwhelmed with too many -too much research driving me crazy.
