wallpaper removal: bucket and sponge or steamer
1 Dec 2007
Hello which of the two options is quicker to remove standard wallpaper from a wall?
bucket hot water or steamer?
Regards,
Score the paper first then use a steamer, dont leave the plate on too long it can blow the plaster .
Having persevered with a bucket and sponge for years, a £25 steamer from Screwfix and a scorer was a revelation.
I was a Pratt and used distilled water from Halfords to stop scaling then figured I was spending more on water than just buying a new steamer.
I had a different experience. I used a tiger paper scorer and sprayed zinsser dif via a garden sprayer. This was more effective than using an earlex steamer which i regret buying.
Whilst I would whole heartedly agree that steaming is the best option, with modern wallpapers you should be able to peel off the top layer leaving behind the backing paper . . . Which almost falls off under gravity when wetted.
Years ago, I stoopidly used Dif in my stoopidly expensive Earlex Steam Master.
It gummed up the inside of the machine.
Often, I just use a paper tiger and spray the wall with a water sprayer. If the paper is the type that peels off leaving the paper backing, I just use the sprayer.
The last time that I used the steamer was to remove masonry paint from smooth render...
