U
undertrained
The red wire doesnt mean that it is live
Just making assumptions based on what I remember from Honeywell training (approx 8 years ago) , in on 1 out on 3.
so many chinese and other countries flooding the market
The reason behind that is the single channel switches the boiler so has to be voltage free switching to suit all boilers, the dual channel will be switchin a 3 way or 2 x 2 port valves which always require 240v , it is the motorised valves that switch the boiler not the hivenot to mention Hive's compromised design of a receiver that was "plug compatible" with "unified" wiring
The Single Channel version has potential free contacts, can be used for 230 volt or 24 volt switching.
The Dual Channel vereion has the two switches internally connected to Live 230 volt,
NO it is true for all Domestic systemsthat is true for MOST systems.
All such systems have to have some hysteresis otherwise your heating system would be switching on and off far too frequently.
It gets complicated. In olden days the heater did as you say, but now it is said that with boilers that do not modulate the thermostat should be switching the boiler off before the room reaches the desired temperature to avoid overshooting the required temperature. There is a thread about this with a graph of the boiler being turned on and off.
why would anyone want to use a Hive with a W plan ?W Plan system as well ?
