I would like to understand the issue before calling in my friendly local engineer.
Over the winter our 8 year old boiler has been fine but is now firing up for a couple of minutes stopping for a couple of minutes then repeating the cycle house rads are all switched off only the cylinder is on.
After someone has showered the boiler fires up for longer then the cycle starts again.
I am assuming that the water in the cylinder reaches its set temp and just switches off.
I would have thought that the boiler would have a built in ability to allow the water to cool off a few degrees before heating it up again but this seems not to be the case.
I see that there is a motorised valve on the pipe to the cylinder and clamped on the pipe is a thermostat. The thermostat is not connected to the valve ( reason unknown ).
I will value any ideas about this and suggestions of what may be wrong.
Currently I am using the time switch to just have 'heating' ( hot water) on for an hour in the morning and evening but thought there may be a more 'sophisticated' solution!!
many thanks
many thanks
