Another alternative, is to fit a wall mounted switch, just out side the bathroom door. Make it high on the wall, but still within reach as a deterrent to regular use. I only turn mine off, when I need to service my shower.
That sounds like a good idea, although clearly a lot more work because of moving the cables etc. What about the risk of people touching it with wet hands if they have to shut off the switch in an emergency?Another alternative, is to fit a wall mounted switch, just out side the bathroom door. Make it high on the wall, but still within reach as a deterrent to regular use. I only turn mine off, when I need to service my shower.
For what purpose?Are you sure it's not a legal requirement? Even for a let property?
It appears to be required under BS7671?For what purpose?
It is not.It appears to be required under BS7671?
I don't believe that's quite correct.Quoting from HERE
Isolator Switches
Isolator Switches are designed to isolate an electrical circuit from its power source. Isolator switches does not have any interruption capacity. It does not have any making or breaking capacity.
Isolator switches are only intended to be operated on open circuit. That means, Isolator switches must be closed on open circuit and then other means of device (like C.B.) to energize line or isolaor switches must be opened after opening upstream device (like C.B.) to de-energize line.
Isolator switches are purely mechanical device and it can conduct normal operational currents as well as under short circuit current for defined period.
Interuption capacity is the ability to break a current without doing any damage to the surfaces of the contacts from the arc that will exist until the contacts have moved far enough apart to break the arc.
