Correct.... here’s my summary. .... When looping at switch, the brown wire in L1 is the switched live and since it is brown, it doesn’t require (regs) any additional identification.
I think it was probably me who started the discussion about 'personal identification methods' so, just in case I wasn't clear, it is something I would very rarely do (and probably never for a simple feed to a single light switch) - I just explained the convention/habit I personally use on the rare occasions I feel it desirable (for my own purposes) to identify a conductor as a switched-live.That said, some may want to use their personal identification method for their own convenience. Yellow was being suggested ...
I personally would not do that. Quite apart from the fact that, as you acknowledge, 'brown on brown' might not even be noticed, I think there would be an appreciable risk that someone else (stupidly) guessing what it meant could well come to the incorrect conclusion. If I were 'forced to guess', I would probably say that 'adding more brown to brown' was probably intended to underline the fact that "this REALLY IS the line/live conductor" (i.e. the permanent L, not switched L)....and in the same vain brown over sleeving can be used as I suggested? May not be very clear as it’s brown on brown but clearly the oversleeving would be much smaller.
Correct.Blue over sleeving cannot be used as it suggests that this is neutral.
Indeed. As I've said, in the absence of anything other than 'personal' conventions' for such identification, no-one else could (should) guess the meaning and not confirm by tresting!As suggested by these “personal” methods, there is a risk of incorrect identification and hence, should always test the wires if working on a unknown system.
