Kids have pulled radiator off plasterboard wall!
And educate the kids! When mine were young we had solid walls, but I don't remember them trying to pull the rads off.
They did here, climbing up to see out of windows, but they are fixed to brick so pretty solid - it didn't prevent them standing on exposed 15mm pipes though and bending them :(
A bit old for that now..
Never too old for toys :D
Youngest has some as in my link, and I was surprised how solid they feel. I think that type would be worth a try, if the holes aren't already too big.
Sorry, I guess you missed my previous reply to you.
The "Redi-drives" that you linked to are rated at 7Kg, that is even lower than the Fischer universal nylon plugs which will hold 10Kg, their metal cavity fixings and gravity toggles are rated at 20Kg
Have a look at the following for a comparison.
http://www.fischer.in.th/PortalData...dfs/Plasterboard_Fixings_Guide_webversion.pdf
BTW I can't see anything wrong with using a drill bit with the fittings that you linked to but they are designed to be self drilling.
OK if those loads are for fixings in plasterboard, as the load will be limited by the board material rather than the fixing strength. With 2 or maybe 4 anchors in pullout, the load would be a good pull for kids.
I agree a fixing which splays out behind the board is likely to be stronger than the Redi-drive, that's why I suggested using the same type, but installed properly, as the originals don't seem to be.
I can't see anything wrong with using a drill bit with the fittings that you linked to but they are designed to be self drilling. Saw that on your link, it surprised me. I'd have thought going straight in without a pilot hole would break up the plaster locally and make the result weaker. But I've never tried these fixings from scratch.
BTW what happened to the OP? :)
Red gripits have a loadbearing of 74kg. Combine that with hatching the plasterboard with a stanley blade and sticking brackets on with clear silicon. :)
Or you can cut plasterboard out with multitool..put stud in between uprights and then replace plasterboard and easyfill.
Gripits are good, expensive though. They recommend the brown ones for rads. I see that they now seem to have some kind of white collar (presumably) to prevent the fitting twisting as the wings are opened.
https://www.gripitfixings.co.uk/products/gripit-brown
