- Joined
- 22 Sep 2019
- Messages
- 4
- Reaction score
- 0
- Country
Hi all,
The evacuation pump on my DW suddenly stopped working. It gives an E1 error, which is faulty water supply, but in fact the water supply works fine: the DW fills, the wash pump engages, but then starts leaking all over the floor because the evac. pump doesn't work. When I start the DW the pump never comes on - during what should be the initial pumpout cycle it's absolutely silent, until it starts the fill cycle.
I pulled out the pump, and there's nothing blocking the impeller. I tested the motor and it shows 121 ohms for the 'high' circuit and 162 ohms for 'low', which sounds about right. Motor spins freely. I started the DW and tested for voltage at the motor, and there's none. Tried to trace back the motor wires but it's a tangle.
Question: are there any relays or failsafe switches that could prevent the evac. motor from engaging? There must at least be a relay off the control board, as the amperage draw must be fairly high.
Hopping one of you has had this problem, or knows enough about the design of these things that you can give me some pointers. Any suggestions appreciated!
Thanks,
-Dave
Thanks,
-Dave
