- Joined
- 27 Sep 2016
- Messages
- 6,262
- Reaction score
- 744
- Country
Another case of I didn't install it but 8mm microbore pipe being blocked.
Combi boiler setup - little or zero maintenance in the last 8 years+ I suspect not even a inhibitor in the system. 9 Rads including a towel radiator - Converted bungalow - Boiler in garage and house on top of garage - So boiler is lowest point.
The highest radiator in the system doesn't get warm hardly. I've had the TRV off (it is checked and working) - at the feed pipe, there is barely a trickle when pump on so assuming that pipe is blocked somewhere - Probably best side of 20mtrs back to the manifold under the main floor in the house and certainly not accessible for the main - Buried in eves, under floors, behind plasterboards etc.
With the TRV off - I've tried draining the system a little then reapplying the pressure a couple of times, also tried a bike pump on the 8mm pipe (again with some pressure removed from the feed side) and still I get a trickle when the system is on. So I know not completely blocked.
I really don't want to have to replace the microbore as much as I'd like too as this would be a huge task given the building works, pipes and location of radiator to the boiler etc.
So looking for recommendations from this forum of excellent members
I am not a plumber by any means ... Give me a Computer Network and I am your man!
My initial thoughts are:
1) Close of the other 8 radiator valves (both sides) leaving the "problematic rad" (PR) open
2) Drain the system fully - assume I need to open the bleed value on PR to allow air in?
3) Install some Sentinel X800 from Screwfix via the PR (see point 1)
4) Repressure the system via the filler loop to 1.5bar
5) Run the heating for 1 hour or so
6) Pray that this works!!!!
7) Let the system coolthen drain
8) Install some Sentinel X100 from Screwfix via the PR (see point 1)
9) Repressure system
10) Open the other rads
In other words HELP!!! - The Mrs is complaining that the bedroom is cold
Shut off ALL rad valves around house. Then drain only THAT radiator.
Then slowly....veeeery slowly refil only that rad.
Then only open the valve fully to that radiator, fire up heating, what happens?
