hey,
we have a pressurised microbore 8mm system and combi boiler - for 90% of the house - perfect all piping hot.
1 radiator (1.4mx50cm double) gets warm-ish and stone cold at bottom. there dosent seem to be any restriction to flow with the radiator off and the system has been cleaned. Thinking we need to seal off the possibly kinked/too small pipes (yay sealed in plaster). and upgrade to 10 or 15mm pipework for this one radiator.
2 questions
1 - is the radiator too big for the pipework
2 - had a couple of guys look at the job all bar one said doable - but pipe should be fine (want to 'clean' first - which we have tried) one stated that pipe is too small but adding larger pipes to 1 or 2 radiators could screw the rest of the system up and stop it working. Is he right?
just wish there was a general consensus on the issue/solution
2 questions
