Rodents entry via air brick and how to block?
17 Aug 2014
Middlesex
Hi all
Heard some scratching under the floorboards last night and I fear we may have unwelcome guests. Hoping it's mice but you never know it could be those 'other' guys :(
I've had a quick look outside the house this morning and noticed that a few of our plastic vents seem to have holes in that I don't recall seeing before. They don't look chewed by an animal - more like a clean break and I can't see any broken plastic bits around on the ground.
What do you think? likely point of entry right? ...
What are the best ways to block entry but allow airflow? I have 5 similar vents to deal with.
Cheers guys ... I image that meshing would need to sit on the outside though somehow. Might not look so great.
I saw some specific rodent proof vents on Amazon - 16 quid a pop seems steep though for a frame and a mesh in the shape of an air brick.
Thinking this might be an alternative - see attached image and could even spray it dark grey to blend in with the existing brick work.
What do you think?
What do you think?
I like it , would keep things looking neat
Mice can get through holes the size of a pencil it's difficult to keep them out ,we have a problem with them at work every year when it starts getting colder
If you haven't got a trap door to under your suspended you could drill a hole in your floor and use an inspection camera to take a peek or stick the camera through the vent to confirm
Failing that chat someone up with a thermal imaging camera!
