Hi
I am after a dummy or even a cheap unconnected dome camera for outside my door ...I live in a flat. The problem with the dome cameras especially the dummy ones is as follows...the backing plate is screwed to the ceiling ( a template is normally supplied to make sure the screws are in the correct position). Then the main dome is simply twisted into place after inserting the batteries. The problem is this means anyone can reach up and untwist the dome to remove it!!. SO I need a dome camera that is fixed in such a way as to make it tamper proof...but still able to replace batteries. The only thing I can think of is after installing the dome camera I could make a hole in the outside rim and put a long screw through to the ceiling..the camera cant go anywhere else other than just above my street door..so this position is accessible to anyone. ..any ideas please? ?..thanks.
