Can I cut this plug off and replace?
Status
Not open for further replies.
UK electrical systems are different to the rest of Europe, where sockets are connected to circuits rated much lower at 16A, as opposed to 32A in the UK. Therefore in the UK our plugs incorporate a separate fuse suitable for the appliance / cable connected to it.
As this plug is designed for use with a lower rated 'European' electrical system, it doesn't incorporate a fuse
And as far as I can tell, neither does this; in common with a lot of similar devices.
Which means that when used in the UK anything connected would only be protected by the 32A overload device in the consumer unit. :eek:
I work in the UK for a large German company and we often get kit with European plugs on, which we simply cut off and fit a standard UK plug with a suitable fuse.
We also have a Nespresso coffee machine in the office and the waste pods are collected by Nespresso and recycled. They make various objects from them including bicycles, and for every bike they sell they donate another one to a child in Africa. Velosophy
It cannot legally be sold into your territory without a BS1363 plug (known as a plugtop to annoy @winston1/GeorgeCooke) fitted.
Not sure that is true. While we are in the EU it can be sold with any EU plug I believe.
Plugs are only referred to as plug tops by the ignorant such yourself who don’t even know what country you are in.
l
That particular adapter does incorporate a fuse.
But the fuse is to protect the cable not the device on the end of it.
OK thanks, I can't see it in the photo. Most I have seen don't.
I deliberately wanted to avoid anyone raising that again it's been done to death and beyond, which is why I said.
After all appliances often have cables inside as well don't they ;)
surely there's somewhere in the jokes archive for threads about plugs and tops?
You're wrong there.
I'm not wrong.
It is indisputably Ireland. Why do you think pro-British elements including the British government refer to it as "Northern Ireland"? They completely accept and admit that it is in Ireland.
It is a fact that it is in Ireland, and one which cannot be disputed.
Maybe the moderators can move this to the special interest area of the forum
Status
