- Joined
- 15 Dec 2019
- Messages
- 7
- Reaction score
- 0
- Country
Hi Guys & Girls!
After a brief search I didn’t find a solution. I’m not clear if I need a Central Heating person, and Electrician or if this is a 30 second DIY job.
I’ve had HIVE for about 6 years and it’s always annoyed me that as per the title, if I want the heating on, I also have to switch on the hot water. In previous houses, the room stat dropping below the threshold could trigger the boiler to do its thing but not in this house.
Switching on hot water makes the Blue device fire (marked hot water pump) and the boiler fires.
Switching on heating makes the red grundfos device fire and pumps hot water from the cylinder around the radiators until the water is cold but never fires the boiler. Is it possible to make this happen? I can’t spot how to wire it so that hot water doesn’t fire the heating too. It should just be the other way.
When the hive installer came he chopped the wires behind the room stat, and these are not connected in the wiring centre at al.
I have attached some pictures and a diagram of what I can identify.
Any tips gratefully received!
Cheers
Cheers
