Hi All,
I recently replaced the glazing in my house, with Georgian effect panes which are made with horizonal and vertical duplex glazing bars, to give the Georgian small pane effect. The problem I am faced with is that the horizonal and vertical spacer bars make up the smaller panes, are a few millimetres smaller than the glazing par which surrounds and seals the window, therefore there is a small gap at each side of the spacer bars. When I push on the centre of the window pane, the spacer bar inside the window moves, hitting off both panes, causing a rattling sound.
I spoke to the glazing company who advised as their manufacturer has made the panes in this way, based on the dimensions of the frame, so it must be right. I feel like the glazing company is not moving on their stance regarding the windows.
Can anyone please give advice if they have experience of this, is this known to be the way spacer bars are made within Georgian effect panes or how I can have this resolved? The older panes which were replaced did not move...
Thanks in advance....
