Hi, I have a Worcester 28Si11 combi. The rads are cold near the bottom and middle so I assumed that I needed them flushing out, Also noticed that the boiler fires up but doesn't stay on long, engineer stated that because the rads are choked up the boiler isn't circulating properly thus keeps cutting out. I also don't think the hot water is as hot as it should be. Quote for flushing has been as high as £700.00 for 9 rads. Looked at hiring a machine myself and really after researching the procedure the only things i don't understand are firstly can I flush with heat exchanger in situ?? and seen comments on switching from rads to hot water, how do you do this?
Any help much appreciated
