Hello,
Any help here would be appreciated,
I have a vaillant ecotec plus 637 with a multi zone setup. The kitchen has underfloor heating and the rest of the house is using rads, I also have a megaflo water tank. I don't have a manifold I simply have a number of valves, one for the UHF, one for the Rads and one for the water tank.
So far everything has been working fine (the setup is around 7years old) but over the past coupl of months I've noticed that the UHF isn't working right - in that only small patches of the floor get warm.
I've tried flush out the whole system to try and understand If there are any blockages...there doesn't seem to be any, as I think I managed to empty the system without too many issues. After filling up and bleeding the system, the ufh still doesn't work. I've had a new pump installed just days ago thinking that it might help but unfortunately it didn't.
One symptoms I'm noticing is that heating the rads or the water tank works fine, Ive set my boiler to 65 degrees. On demand the boiler goes up to 65 and stays there (or there abouts). But if I turn the UHF on only, the boiler goes up to 75 degrees, heat cuts off, the boiler temp then goes down to 40 before firing up again.... And the cycle repeats. This seems a bit odd and I don't recall it ever doing that before.
I did have a major power issue back in Dec while I was abroad, a came back to a very cold home to find the mains fuse had dropped. part of me thinks that the boiler config could have gone back to factory settings, but then again the settings should be saved.
Anyone here able to help me diagnose what could be happening. Pleeeeease?
Sups
Read more: https://www.diynot.com/diy/forums/plumbing/create-thread/preview#ixzz6D0DT4WA5
Sups
