I have a hot tub coming mid March and plan to put it where we previously had a pool.
This is the area being prepped for the pool:
Basically grit sand over old slabs with plastic grass on the top. It’s flat but not level, you could tell this when the pool was full.
So i’m thinking to either:
1. Dig out an area about 3mtrs square and put a level/flat concrete base there and cover it with the grass
2. To cut the grass, lift the slabs, make a level/flat frame from decking so there’s a step and then pour concrete behind that. I could then stick the grass back on the top.
3. As per 2 but leave the slabs in place.
4. Lift the grass, level the sand, replace the grass. With that i’d be thinking the sand might wash away during heavy rain.
Once the base is done I would like to make a frame that could have a removable roof to protect from rain/sun but not sure where to start with that. I saw this online but it’s a bit ugly:
Any thoughts on what’s best?
