Fixing to conservatory ridge beam
14 Sep 2004
I want to get a solid fixing to the ridge of my conservatory to hang a projector . Not sure if there is anything available to do this, or if I need to construct something :D The projector and mount is about 3.5kg, and I'll need an extra bit of something to drop it about 90cm which might add what, another 1kg (this bit still TBD depending what kind of fixing to the beam I can make)
The beam is aluminium I believe, and 15cm wide. The top of the section is flat and cannot be screwed into, but it does have what I can only describe as wings on either side that the plastic covering clips to and have some space above them. These wings are about 4cm wide but I'm not sure how easy it would be to screw into those.
I was wondering if there was something available that I could clamp around the wings. I've tried to draw a simplified cross section of the beam, so something could grip along the whole of the wing, or dig into the channel.
Or perhaps I could bolt a plate in from the inside that would be hidden underneath the plastic cover?
Or another thought that just crossed my mind, I could drop 4 threaded bars from 4 holes in the wings - would make for easy adjustment?
Dave
Why, with regards to "The top of the section is flat and cannot be screwed into"?
I ask as I would get a square of ply, say 11cm by 11cm square.
Drill four holes into this wood.
Get some metal self tapping screws.
Use wood as template to drill some holes slightly smaller than screws into flat area of metal.
Screw this wood to metal using the self tapping screws.
Paint black or brown.
If you wanted you could then screw another layer of ply (perhaps 10cm by 15cm to hide the metal) to the first layer of ply so you have say 2 x 18mm = 36mm thick wood, which would be perfect to securely screw the projector mount to using 30mm wood screws.
Or pull plastic cover over the wood and screw though the plastic cover into the wood to have a hidden effect.
( I would use ply over say chipboard as easier and more square to screw into. A pine plank would also work.
SFK
Dave
I didnt want to drill into that top flat part for fear of going through to the outside or otherwise damaging what is on the other side that I cannot really see. Otherwise, I like the idea :)
Well I would use Slef taping screws that are say only 10mm longer than wood thickness so that will not go outside.
Or, Wider wood , say 15cm.
And drill and screw through wings.
With fingers between wings and roof to make sure screws are not too long and go through roof.
