- Joined
- 4 Mar 2020
- Messages
- 4
- Reaction score
- 0
- Country
Hi all,
I bought a 1950s bungalow a couple months back and have been slowly renovating it. One of the first things I did, was to redo all the pipework from the boiler to all rads, and replaced all the radiators. The boiler itself is a Bosch boiler which is around 7yrs old. Seemed fine when I bought the place so decided no need to replace. It has one of the "older" style engines in it, which I understand to be better built quality then some of the newer ones.
I replaced the piping (old 8mm) with 15mm and 22mm. 15mm to each rad and 22mm everywhere else. The rads are extremely oversized as I run my boiler with a 55deg c flow temp to keep it in condensing mode (return if circa 45). My issue is that the boiler sounds like it's going to shake itself off the wall now. It's the strangest thing I've ever heard a boiler do. The vibrations are insane. But it doesn't happen all the time. I am unsure if it is the pump, fan or perhaps the expansion tank. Anyone ever had this issue or any ideas how I can test each part so that I can replace the broken thing rather than pot luck it and spend a fortune.
Thanks in advance
Thanks in advance
