How does leadseal do the job of mortar?
26 Nov 2011
Somerset
Putting an apron flashing into a roughcast rendered brick wall.
Cutting blind into the render. So the chase 15mm wide 25mm deep, may be mid brick or hit the mortar bed, or a bit of both
Whichever I finish with I will use hall clips to hold the lead in place.
If I use Leadseal and the chase 'lands' into the mortar bed as opposed to into the face of the brick,
is there not a chance the bricks will move without mortar?
In a plain (unrendered) brick wall, is really ok to rake out an inch (or more?) and finish with leadseal? Doesn't the wall need that mortar to remain stable?
25mm makes no difference.
..... whatever you fill it with....?
I wasn't a brickie when 'the new way' - mastic filler- came into play.... I bet someone would have asked how mastic gets by doing job of mortar....
is it really immaterial?
Thanks for the input.
