I have almost finished my upgrade to my central heating. i.e. all new radiators, new pipes etc.
The combi boilers built in bypass is set to maximum at .35bar.
The existing system is a Valiant ecotec plus with 22mm used for about 1/4 the run and the rest are 15mm, 6 rads for 10KW.
I was going to fit a bypass valve in a accessible cupboard at the end of the 22mm run. Is it simply a matter of fitting it and setting it to say .3bar such that the combi boiler bypass stay closed? Or is the combi bypass meant to be disabled?
I was thinking of adding smart TRVs, as it currently stands if I close off the largest rads. The pump is either cavitating or there is some other noise that it is making, even with two small radiators acting as bypass but to set a low flow for balancing purposes.
