will not make a difference if your internal pipes are 15mm
It's a big failing of a lot of installations where people cut their distribution pipework to 15mm as it's easier/cheaper to install.
A lot of people don't realise that the outlet experience (how good the water coming out of the tap is personally appreciated) is to do with water velocity (noise) and resistance (pressure and flow reducing friction), not just the flow and pressure especially when looking at whole house overall performance. Depending on the size of the house and how many and the types of outlet are used within the property will determine on how the pipe runs need to be designed and what size the pipes actually need to be.
It is quite a technical excercise to get the design right, not what a lot do and just fit and hope for the best. Basically it comes down to whether the customer is happy or not but if they've never seen how good it can actually be, then they don't know what they're missing.
Perfect example was one re-pipe I did at the tail end of last year. Mains stop tested @ 2.5bar @ 18L/Min on a 25mm MDPE supply but at the street it was confirmed as 3.5bar @ 26L/Min so we knew there was headroom there to optimise.
3 bed/3 bath (2 en suite) semi in glasgow circa 1980's with a system boiler and unvented HW. Lousy pressure and flow (average 1.5 bar with 10L/Min dynamic) anywhere except the kitchen and utility (2bar @14L/Min). The customers reason for wanting it looked at was down to the showers not being able to cope being run at the same time without significant impact to each other. All pipe work was found to be 15mm 1m after the main stop tap on a 25mm supply except the feed to UV which was 22mm but then the distribution from the unvented dropped to 15mm 1m after the cylinder (absolutely criminal IMO) .
Increased the mains to 32mm and replaced 75% of the distribution pipework to 22mm until the last branch to each outlet. Bends were kept to large radius' and removed 18 elbows and tees with better planning. All flexi's removed and outlets hard piped where possible, stop tap and ISO's changed to full bore. All free flow outlets subsequently increased to an average of >2bar @ around 20L/Min flow dynamic, all showers changed to bristan bar showers and all 3 will now run well at the same time - customer couldn't believe the difference or the reduction in water noise.
