32mm mdpe or 25mm
Discussion in 'Plumbing and Central Heating' started by xdrive, 27 Apr 2020.
  1. xdrive
    xdrive
    2 Mar 2019
    261
    Thanks Received:
    2
    Country:
    Hi.
    Replacing lead pipe. Having stopcock on road renewed. Neighbors say flow is good.
    Do I use 32mm or 25mm? House has been extended with dormers. 3 floors 2 bathrooms.
    I've dug trench between 700-750 deep. Do I insulate pipe or duct it? Will lie on subfloor when inside.
    Cheers
  2. Sponsored Links
  3. dilalio
    dilalio
    20 Mar 2009
    8,186
    Thanks Received:
    1,374
    Potters Bar
    Country:
    Depends what stopcock/meter is being fitted... Usually no point in using 35 unless supply is around that size. 25mm usually and bed it in pea shingle at the bottom of the trench. Might want to lag it in the house but mdpe doesn't really suffer from condensation that other pipe materials can do.
    • Like Like x 1
  4. Madrab
    Madrab
    4 Oct 2012
    8,568
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    Rarely would I contradict the pro's on here, especially @dilalio - ;) - but if the mains pressure and flow can sustain it then no reason not to go to 32mm to maximise your supply.
    If you are having the lead mains replaced though, you really should be getting a note of what the mains flow and pressure and the pipe size would be. Specifically to answer your question.
  5. JohnD
    JohnD
    15 Nov 2005
    75,091
    Thanks Received:
    4,361
    Crossgates, Europe
    Country:
    Cook Islands
    That's how I look at it.
    The cost difference in pipe is not much, and the effort is the same.
    The big stopcock is dearer, though.
  6. xdrive
    xdrive
    2 Mar 2019
    261
    Thanks Received:
    2
    Country:
    That's what's stopping me. Is there a way around this ?
    What if I get 32 to 32 stop cock then use reducer from 32 to 28?
    Would you use 22 or 28 copper?
    Does the water company have to attach blue pipe coming into to my side from road stopcock? If it can be done by plumber then will let water company install them then see what they have used and get same size.
  7. JohnD
    JohnD
    15 Nov 2005
    75,091
    Thanks Received:
    4,361
    Crossgates, Europe
    Country:
    Cook Islands
    I'm not a plumber.
    When I replaced lead with plastic, I used the large size and took a 22mm cold and a 22mm for the hot off it, with the idea that neither would steal flow from the other, even if you're running two baths or showers.
    Dilalio will have done lots so knows better (hope he isn't offended by DIYers)
  8. xdrive
    xdrive
    2 Mar 2019
    261
    Thanks Received:
    2
    Country:
    If I use similar set up but with 25mm mdpe (bore size 22mm) to 22mm copper hot and cold would I be unable to run 2 showers at same time from boiler?
  9. JohnD
    JohnD
    15 Nov 2005
    75,091
    Thanks Received:
    4,361
    Crossgates, Europe
    Country:
    Cook Islands
    Don't know. I did it by eye. There is a way of calculating it.
    Flow was fantastic afterwards.
  10. Sponsored Links
  11. Madrab
    Madrab
    4 Oct 2012
    8,568
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    Unfortunately that isn't dictated by the size of the mains supply unless you are using an unvented cylinder. If it's a combi boiler, it will probably struggle no matter what size of pipe you use I'm afraid. It can be designed to work but it needs tight control on the shower types and fittings to regulate the flow from each.
    TBH - the price difference between a 32mm stop tap and a 25mm stop tap isn't that much in the grand scheme of things IMO.
    • Thanks Thanks x 1
    • Like Like x 1
  12. xdrive
    xdrive
    2 Mar 2019
    261
    Thanks Received:
    2
    Country:
    What size stopcock did you use? 32 to 22m?
  13. JohnD
    JohnD
    15 Nov 2005
    75,091
    Thanks Received:
    4,361
    Crossgates, Europe
    Country:
    Cook Islands
    Two @ 22 indoors.
    Outside, the water meter had its own stopcock
  14. Madrab
    Madrab
    4 Oct 2012
    8,568
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    I'll get me coat!! :whistle:
    • Like Like x 1
  15. xdrive
    xdrive
    2 Mar 2019
    261
    Thanks Received:
    2
    Country:
    As the mdpe comes in to the property it is around 550-600mm. It will then lay on subfloor for 7metres and finally come up in kitchen.
    Do I need to use lagging/ducting on of what sort?
    Also I would like a garden tap. Is it best to take of the mdpe? Cheers
  16. Madrab
    Madrab
    4 Oct 2012
    8,568
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    Have as look at this thread, the post from @Hugh Jaleak, if anything as @dilalio suggest, you can use a pea shigles or sand for the trench. The insuduct is an excellent way to bring the pipe out of the ground and into the house.
    • Like Like x 1
  17. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,471
    Thanks Received:
    1,761
    Northamptonshire
    Country:
    • Thanks Thanks x 1
Loading...
Share This Page
