Hi
We have a septic tank and the waste is not flowing properly and I've dug down to expose the waste pipe and found there is no fall to speak of. The waste pipe runs between a chamber and the tank and is almost level, in some areas even slighty uphill according to my spirit level. I've only recently moved to this house and only finding these things out now.
I am not keen on digging the chamber out I guess I need to try and find some depth at the septic tank end and reset the whole lot, I could probably get additional 10-20mm over 8m run. i'm answering my own question here, unless I invest in a pump!
I'm almost thinking this means a new septic tank but not an option financially at the moment, I think the flow is good to the chamber just not between the chamber and the brick manhole of the tank.
Note sure this is even a question, but would be good to hear if there are any ideas out there.
