- Joined
- 2 Mar 2020
- Messages
- 86
- Reaction score
- 13
- Country
Before you jump down my throat, I've had a good look for my specific questions on this forum and other places and have found many useful answers. However there are a few more questions which I could do with resolving before I drop a clanger on purchase and installation.
The system will be a 4 - 5 camera POE installed on a semi detached bungalow. The cameras on the front and rear will be approximately 2.4m above ground level.
I intend to use 5mp or 8mp Hikvision Darkfighter 2.8mm lense outdoor cameras, possibly anti-vandal domed. However I would much prefer to remove the existing security light adjacent to the front door and replace it with one of those integrated light/cameras. So far I have not found anything compatible with a POE system therefore I may just remove the light and install a camera in its place as it will most likely be affected by light pollution or whatever the term is.
The other key install criteria is location of the NVR recorder. If fitted underneath the TV in the living room would the constant whirring of the disc drive be annoying or would an SSD be a better option?
If the NVR was mounted in another location would I still be able to view the cameras via the TV which is connected to the house network for Netflix.
Can the NVR be controlled/setup with the laptop as opposed to the remote if mounted remotely?
Are 8mp cameras okay to access via the Android phone app or is it too much data? I'm hoping the App does some sort of encoding to make it viewable.
Is it possible to set up movement detection alarms to notify on the phone app at different times of the day for different cameras? e.g. Front of house no alarm until after 22:00 but the remaining all day.
Also if a covert camera can be used at the front door, is zoning of motion detection available or is this tied in with the specific cameras as supplied by Hikvision or a software setting?
I will get pre made cables cat 5 or 6 if there is any preference and wonder if weatherproofing is required for termination in the back of the dome cameras?
I hope I've made myself clear on the above and your replies would be appreciated before I splash out on some kit.
Many thanks
Pete
Many thanks
Pete
