I have a non-return valve on the mains feed into a Zilmet expansion vessel. The valve includes a quarter turn shut off tap (to the left in the attached photo) and this tap leaks (sprays water up the wall) in any position between open and closed, and drips in the open position; thankfully it doesn't leak fully closed.
I just wondered whether there's any adjustment available on these valves to stop the tap leaking, or whether I need to get a replacement valve fitted?
The black plastic tap sits onto a double D shaft, so the screw in the end just holds the tap on. I'm not sure whether there would be any adjustment options under the inspection cover on the opposite side (on the right in the photo)?
I'd be grateful for any thoughts or advice.
Joe
Joe
