Mine was - when it shouldn’t have done. Just like yours. Just remove it.I'm not sure why it would be working at all if it were in place tho?
Fair. It's out.Jesus mate just remove the link, if it all goes t1ts up put the link back in, the fact you have a wire to the 240v rt means you cant have the 24v connection as well.
Oh I know. There's no link whatsoever. Just bad timing!The jumper has absolutely nothing to do with your taps, it is simply a signal link, your boiler thinks you want the heating on, the HW is completely seperate
Then take the link out before you damage the boiler.Oh I know. There's no link whatsoever. Just bad timing!
Just looking at the instructions and it doesn't seem to suggest it needs removing unless you're using 24v controls... Am I misreading?
Did you post an edited photo?You’re misreading. See edited photo, it states if using 230v controls, then remove link at x100, which evidently is the 24v linkAlso please ensure that since you have removed the case, which forms part of the room seal, that it isn’t checked in accordance with gas safety installation and use regulations 1998, after performing work on a gas appliance.
