- Joined
- 27 Jan 2008
- Messages
- 27,409
- Reaction score
- 3,309
- Location
- Country
I believe they're talking about cables high on walls falling on firemen.I've seen/read that come the 18th edition cables need to be adequately supported in the event of premature collapse, so I was thinking the easiest way is metal cable clips clipped ~50mm below the top of the joists.
Hi. I would like to extend my ring main which I understand is non-notifiable.
I suspect you are just making that up. Please provide proof.That is notifiable if extending means more sockets.
You are quite right.Hi. I would like to extend my ring main which I understand is non-notifiable.
It is not notifiable - but what would be the point if not for more sockets?That is notifiable if extending means more sockets.
I am interested in what you think the difference is between the two.Spurs off an existing ring are ok
We all make typos but the 'm' and 'r' are some distance apart.or using mcbo's
Where did that rubbish come from?That is notifiable if extending means more sockets.
that's probably true, given that current regs are such that any new sockets should be RCD-protected. However, that can theoretically also be achieved by using RCD-sockets or, if appropriate, wiring the new socket(a) as fused spurs connected via an RCD FCU.However I am pretty sure an electrician would want an rcd in the circuit if sockets were added ...
Some people love arguing. However, even for them, there's a limit to how much arguing they can do as regards Part P, given that it is just one sentence!On a certain other forum some love to read posts by electricians that are arguing all down to Part P and how it's written.
I presume you mean with an RCD in it. If so, it's a reasonable question, but one answer is that it is not applicable for a ring final circuit.It now seems to be pretty common for them to use an rcd fcu when spurs are added when there is an outdated CU, say Wylex. Done on the basis that their work is left safe and complies. I asked why not protect the entire circuit the spur is on using something like this....
Again, I presume you mean 'a box containing and RCD' - in which case, as above, it would not be applicable to a ring final.Or if some one wants to rewire a room why not protect it's power circuits the same way. The "box" could be in the room.
Indeed, the requirement for any new 'buried wiring' to be RCD protected will often trump the requirement for RCD protection of sockets. Even adding an RCD socket (to a non-RCD-protected circuit) is not compliant with current regs if it involves new buried cable. In such circumstances, it would be possible to add new sockets as fused spur(s), if the FCU could be installed adjacent to an existing socket, since the FCU would then protect the new downstream wiring [as well as the socket(s)]. Some, of course, might even then argue about the couple of inches of cable between the (existing) socket and FCU!Personally by the way I think the rcd aspect is added due to the catch all about cable protection ...
