Hi
I have had a Honeywell G2-20 for nearly 5 years now and have previously replaced the battery a few years ago as I was getting a BAT MISS fault on the alarm.
Recently, I started receiving the BAT MISS fault on the alarm again so I purchased a brand new replacement Yuasa NP7-12 battery from Rexel.
However, the BATT MISS fault still appears and disappears every few hours.
I did test the voltage on the new battery before installing it and it was 12.67V.
The battery is connected correctly.
I did also try to restart the alarm using the engineer options but this hasnt helped.
I have read from previous faults that it may be the PCB that is faulty. Any other ideas?
Also is there a way to get the alarm to ignore the error temporarily so I can exit engineering mode and set the alarm?
