Basin tap
5 Nov 2009
Liverpool
Hi
Just replace my basin and taps with mono mixer along with m10 flexi
The hot water flow is poor
If i remove the isolation and replace flexi with copper m10, will the flow improve
My old basin worked great with 2 taps
Any help appreciated
Try connecting the flexi to just the isolation valve, and fill into a bucket, if this comes out ok, I’d be looking if the tap is suitable (as per @denso13).
Thanks andy
Can you send a link who sells low pressure taps.
I have tried ebay unable to find.
The only one that may work could be the Victoria taps due to having cartridges.
An old-fashioned tap with a washer is likely to be best.
Individual taps rather than mixers.
The best make I know is Bristan
If you look at the "regency" basin or bath taps you will see the shape
though they might not be to your taste.
I notice they are not as big as similar taps removed from a 20-year old bathroom. I suppose styles have moved on.
Have a look at Screwfix. The product info says whether suitable for high/low pressure or both. Of course it will depend on just how low your pressure is. 0.1bar for every metre of height between tap and cold water storage.
Hi
Current tap is 162611
Planning on purchasing 162614
Says low pressure and gravity
