Retaining wall - wrong blocks?
24 Dec 2015
I want to build a retaining wall in the garden, just two blocks high, and have got 100mm thermalite shield blocks. Selco websites says they have high moisture resistance, and are good for both external walls and foundations, so I thought fine for a little wall!
A friend has just advised that they are not at all suitable and I should have got 7N blocks.
Would appreciate any advice on here. If they are too absorbent, could I paint the side that will be in contact with the soil?
Thanks,
Mark
Actually, just re-read. For a retaining wall, thermalites are no good at all. They literally have no strength to them.
I've been building my extension with thermalite shield blocks on the inside skin. You can pretty much snap them in two with your bare hands. Sorry.
Depending on how much retaining your wall is going to do, you need to consider the foundations and the width of the wall. You may need to lay concrete blocks on their side and build up if you've got 450mm of soil and a slope behind the wall to hold back.
There's not much behind it, just pond and patio, nothing higher.
So, not a retaining wall then...just a wall :)
Either way, thermalites will chip and crack with minimal contact.
far too soft -thermalite shield blocks are like a crispier version of polystyrene.
An easy way is to sink 4ft concrete fence posts in by at least 2 foot and use the concrete gravel boards. For extra strength cut the boards to 3ft lengths with some pea single behind them to help with drainage so the wet soil no constantly against the boards. If you already bought the thermalite blocks you can make a small wall in front of the boards and render it with some capping on top.
