A Small Rant About Compression Fittings
11 Jan 2013
Durham
Poxy things. Mixture of old and new tube and fittings. A brand new 22 on fresh clean tube took gorilla torque to slow the leak down, in the end had to resort to Boss White and PTFE to stop the rapid drip.
Then I get another slow drip- another new fitting on a bit of old tube. Quickly found it was only finger-tight, half a turn and dry. Grrr.
Rant over :)
Cheap and nasty "brass" olives too hard to crimp, I often ditch them in the scrap bag and fit copper.
Should have mentioned copper olives. I'm the same as you, the brass ones go straight in the scrap bucket.
That is a valid point, the one needing gorilla torque was from TS, the other one had been in the bits box for many years....
I’m opposite, I prefer brass olives to copper, I usually find they leak all too often, swap for a brass olive and it’s fine. Conex still good, they used to be?
Rant over :)
maybe your over tightening from the start
i use fernox jointing paste on every one.
small bit on the threads and a smear around the olive.
That may be the key, I used to chuck boss white and ptfe at them til getting told if they're done right you don't need all that. Currently I've got 3 or 4 where for whatever reason the joint isn't perfect so have chucked gunk at them, the rest are clean.
Probably totally wrong but I find a bit of Vaseline used to lubricate the olive makes compression joints much easier to tighten. None of the "creaky" sounds as the nut crunches down onto the olive.
( other brands of petroleum jelly are available )
And a fine excuse for having a pot of starters in the van :)
If it’s not wras approved or suitable for potable water then it’s wrong for potable water might be ok on a heating system or other non potable water. Wouldn’t entertain it for gas.
