Shower door seals
28 Nov 2010
Strange question...my shower enclosure door has started Leaking onto the bathroom floor. There is a long vertical magnetic strip and the plastic horizontal affair along the bottom. As it stands the vertical strip is the whole length top to bottom, and the horizontal is cut short to accommodate the vertical strip..hope im making sense. Is this correct ?? To me the strip on the bottom should be full width ? Or maybe not...it has however in its current set up been fine for years until just recently. When I tested it the water wells up and over the metal threshold in the corner where the two join. I’ve googled this and can’t find an answer ? Any ideas folks ? Cheers Rich
Any pictures? As they say, a picture is a thousand words
There you go. Cheers
