This death trap gets even worse!
Andy
Andy
I think those injectors (certainly many diesels have them) have "leak-off" pipes on the top of them. These are low pressure rubber pipes that all join together and return any fuel that leaks past the injector seals, to the fuel tank. Normally, when the engine is running, there's not much (if any) fuel going through them.
Maybe after the "3.5 years, 68,000 miles" it just went faulty. Like many other things on this car.
I probably don't remember well, but wasn't the "handbrake car" a Vauxhall?Maybe after the "3.5 years, 68,000 miles" it just went faulty.
It was a coincidence that it happened after you had been to Quickfit.
I did what everybody keeps banging on about, took it to a garage and immediately there was a problem 10 minutes after leaving the garage. That is why I do not bother taking it to garages often.OK, but do you think it's possible that the sudden disabling of the injectors, to which the OP refers, could have caused them to leak some fuel?
I did what everybody keeps banging on about, took it to a garage and immediately there was a problem 10 minutes after leaving the garage. That is why I do not bother taking it to garages often.It's a Fiat, so anything is possible.
That's a very odd one, I must say! And odd for a variety of reasons.
1. If you were replacing an exhaust clamp and you cross-threaded it so that it wasn't tight, I guess that could have been your exhaust noise? However, if the guy from KwikFit cut it off to stop the noise, what did he replace it with? Why did you fit it in the first place? Did he just leave your exhaust with no clamp on that joint? Or did he fit a new clamp and not charge you for it? That's not really in KwikFit's nature!
2. Doesn't that Fiat engine have a cover over the top of it? Did you take the cover off to see the injectors?
3. I think those injectors (certainly many diesels have them) have "leak-off" pipes on the top of them. These are low pressure rubber pipes that all join together and return any fuel that leaks past the injector seals, to the fuel tank. Normally, when the engine is running, there's not much (if any) fuel going through them. However, if you were driving along and the injectors suddenly went open circuit, you'd have pressure in the fuel rail but the injectors wouldn't be opening and closing. I'm not at all sure about this, because I don't know exactly how they work, but is it possible that under those circumstances, you suddenly had a load of fuel with nowhere to go, and it went down the leak-off pipes? If so, is it possible that three of them has cracked / split / leaked where it pushes on to the injector? Is it possible that once the injectors were opening and closing again, there was no fuel going down the leak-off pipes and therefore, the leak stopped?
I realise it's a tenuous theory, but I put it out there in case anyone who knows more about these engines can comment further.
Andy
