Is this trim suitable for the Metro tiles?
30 Mar 2015
I've come across this trim which seems to be priced cheaper than anywhere else. It suggests that it works for up to 10mm tiles
I am using these tiles as a splashback:
The details state a thickness of 6mm and I assume that's in the centre and not the bevelled edges?
Can you please provide your advice on the above. Thanks in advance.
I used 6mm trim with similar metros along the thin uncut edge. It's a bit tight with adhesive but was better than 8mm. I had to get it ordered in at a local tile shop.
I suppose this wont always be the case as some rows butting up against the tile trim may have the cut (deeper) edge of the tile? Therefore do I need to assume a 6mm depth?
