silicone
2 Oct 2016
Essex
Hopefully a straightforward enquiry folks.
I've had to run a narrow bead of silicone to fill a slight gap between 'screen & the shell of the car, a task has been accomplished without drama, but due to my general ineptitude there are traces of (cured) silicone on both the paintwork & rubber seal.
I wiped off most of the residual with a damp cloth directly after the application, but how best to remove the remaining smears ... do I use products such as meths/acetone/ white spirit etc ?
Obviously damage to the (silver) paintwork needs to be avoided.
Any advice will be appreciated
Stay safe all.
Modern paintwork is amazingly resistant to many chemicals, including what you have mentioned here with the possible exception of acetone.
Naturally enough, if the car has been resprayed at some time with cellulose - highly unlikely these days - we may have to think again.
Anyway - see if you can rub the residue away first with your finger, but if that doesn't work, try some white spirit on a cloth such as shop towel.
John :)
Done the other day for an internal door cart.
Use white spirit generously on a cloth, rub the silicone and then use a plastic tool to take the silicone off (i used a plastic knife).
The silicone will probably come off in layers, so repeat the process until clean.
I have done it on an old VW, where there's proper paint, a more modern car might just be stripped, so test the white spirit first.
I find meths is about the safest all round solvent - except on french polish.:eek:
Peter
John :)
Thank you John.
Because that is what is used to fit windscreens to the body. Why would you not use it?
'Hmm, do I detect a note of rebuke :unsure:
Probably because I had a new tube of good quality silicone & considered that a good alternative to purchasing expensive specialist adhesive that I would be unlikely to have any future use for.
