Replace combo boiler with a flush
11 Jun 2013
London
I know the combustion chamber is out of bounds and I’m not trying to break in..
I have a combo boiler that needs replacing. It’s a badi and it’s about ten years old and has sludge
what sort of money should I expect to pay to have a new one installed and the existing pipe work flushed??
It is six radiators and a two bed flat.
I’m guessing £900 for the boiler and what for the labour and flush so a days work or am I crazy
is it also worth replacing all the radiators at this point or anything else to future proof system?
Thanks all for a great forum with tons of info !!
Depends on what area of the country you're in. If you're in London as your profile suggests then you could be looking at the best part of £1000 for a day's work. £900 will buy you a mid-range boiler, but the flue will be extra. If your present control doesn't comply with Boiler Plus regulations you'll need to have that replaced with one that does. Your installer will need to establish whether the current gas pipe is the correct size, and if not it'll need upgrading.
In other words, much more info is needed to give a guide on price
Here are some pictures - It needs a flush obviously
Im not sure what other info would be needed
Im thinking of replacing the Baxi 600 / Baxi 800 - Any ideas on the difference
1. There is nothing in the photographs which shouts "sludge!". Looks as if you have had a leak which has gone unchecked / unnoticed at services.
2. The boiler casing has rusted, so you are probably in need of a replacement.
3. When you get it replaced it would be sensible to:
3a. Have a power flush done anyway, although you might get away with a chemical flush done BEFORE the old boiler is removed. So a chemical + hot water flush.
3b. Make sure you get a magnetic filter fitted to the return pipe on the new boiler to catch any further sludge.
3c. I wouldn't replace the radiators. Provided they are sound and internally clean, why go to the extra expense. Also, it doesn't future proof anything, and add a good bit to the cost.
3d. You will probably need new controls to conform with current regulations.
4. Once it is installed, make sure it gets an annual service. Check with the installation manual what a service comprises, and make sure the attending engineer does it all.
5. Very rough guess on costs:
5a. Boiler and flue £1,200
5b. Filter and controls £450
5c Labour - installation £700
5d. Labour - power flush £500
6. Boiler make - down to personal preference, I like Vaillants but others will have their own views.
7. To a large extent it doesn't matter what boiler you have, the key to long life is in the installation.
Thanks for such a comprehensive answer.
Why do you advise against new radiators? They are around £30 each and will have rusted after years in the flat. Isn’t this the time to change the rads when the boiler is off and the pipes all getting flushed? If not now when exactly?
I had a rad replaced a year ago. £150 for labour to drain and swap out
If you swapped the rads and pipework and went for a full wet upgrade, then you wouldn’t need a power flush, but I’d be looking at an independent review of your current setup, obviously we can only advise on photos and descriptions, but there could be some detail that’s lacking.
I won’t be replacing the pipe work. Just the rads and trv and boiler
Is replacing simple white rads really that expensive?
Not really, but we don’t know if your currents rads are imperial or metric, so could be additional pipe costs and then you’d still need a flush of some sort depending on your water sample quality.
Have you been told you have sludge?
If you are changing the rads and the boiler you wont need a power flush, a quick chemical flush as part of the boiler swap will be fine
I’ve been told I have sludge by none other than British Gas. I know they are not great but the boiler has been playing up for years and one rad had a pinhole leak and the boiler is ten years okd and winter is coming.
so yeah I m pretty sure I have sludge
I had someone come over today in London
gas safe engineer recommended.
he wanted £600 for labour to flush replace boiler and flue and add a filter. He will also give me a gas safety certificate. No radiators to change
That does not sound too bad although it will take him one day max so £600 for a days labour is mot so bad
anyway I think it’s useful for others to know in case they are weondering
