I am planning to build a snooker room at the bottom of the garden. The plan is to build this as a glorified shed but due to the size will need to meet builing regs. The building will be about 8m x 5m internal area so will exceed the 30sqm limit, and i also hope to build it closer than 1m to my boundary (approx 500mm to allow access for maintenance only.
I am sure i will come up with many questions as i go through the project but the first 2 things are
1 - what would you construct the foundations from to meet building regs. will a slab have to meet the same regs as a house/extension? Timber is probably cheapest but not sure this is best for a snooker room. Solid slab probably the most expensive especially as being at the bottom of the garden would need a lot of muck to move and expensive concrete pumping. I am not scared of some hard work and have hand mixed some big slabs in teh past but this might be a bit much in one day. Should i go strip foundations with block and beams screeded?
2 - what would you construct the walls from. Was thinking timber frame but again what would be needed to meet regs. i understand the timber can be varnished to make it fire retardant close to the boundary. I have built masonry cavity walls before but this would move into the realms of planning required too wouldn't it?
Any help appreciated so thanks in advance.
