What is this bolt mechanism called?
17 Feb 2014
Berkshire
Does anyone know what this mechanism at the top of the bolt is called? It's for turning the bolt by hand. The flat metal 'finger' acts as a lever to turn the bolt using your fingers and thumb and it also pivots up and down. The bolt attached to the mechanism is M10. I want to get hold of something like this but haven't got a clue what to search for in google. Any ideas?
Not identical by any means but you may find that trailer 'antiluces' could work for you.
John :)
Thanks, appreciate that. Yes its similar to what I want. The mechanism needs to be detachable though so I screw a bolt into it - all the antiluces seem to be either with bolts moulded on or can only be attached to a bolt by welding. Close, but no cigar! :)
