Hi
Can anyone advise how Opentherm wiring should work with an S Plan system (1 heating zone)? I'm looking to add smart control and was going Hive but learned that my boiler (Logic+ Combi 24) supports Opentherm so that might be a better option and lead towards Nest which supports Ooentherm. However, I'm struggling to understand how this would be wired with an S Plan system.
From my understanding, in S Plan it's the Honeywell valves that call for heat once the valves are open. However, with Opentherm the only wiring diagrams I've seen have the Nest connected directly to the boiler OT connections. So as I see it, that would fire the boiler before valves had opened, and would be dangerous, so there has to be some way to trigger from the valves. Is this possible, or is Opentherm only really practical for a Combi setup?
(For clarity, my boiler is a Combi but being used as a system. The DHW side is simply a tap direct from the boiler in the garage. Not sure why it's like that, only recently bought the house).
Also, does Opentherm make a worthwhile difference over and above going with a smart control system anyway? (Don't have TRVs yet so that's another job).
