How to connect my electric cooker? (Duplicates merged)
28 Oct 2020
Australia
Hi guys,
I'm trying to connect the electric cooker but the cables won't fit under the screws and some of the screws are completely unscrewed and won't screw back in.
I have attached images.
Any help would be appreciated.
Thanks.
Hi guys,
Thanks.
Looks like you're in Australia.
IIRC you usually have a 3-phase or split-phase supply for big cookers, is that right?
Your connection block looks like it can take single phase or 3-phase wiring, and your supply cable looks to be a (very large) T&E single-phase cable. What's the voltage? Did it previously connect to another large electric cooker?
When you undo the screws, is there a large, loose washer underneath, shaped to trap and clamp the core of the cable under it? When pushed in from the "trough" down the middle?
I think your connection block should have markings by the terminals, and a hinge-up lid, and a cord retaining clamp. Is it second-hand? And do you have the instructions?
There seems to be one brass connector missing.
It's hardly likely to require 10mm² cable.
How do you know what size cable that is in the photo? It seems to be 7 strands, but could just be 4mm. The 'flexible conduit' end, needs to go into some sort of adaptor, to take the strain off the terminals.
