Connecting Belling Kensington 90e range cooker
29 Oct 2010
Somerset
Does anyone know how to connect a Belling Kensington all electric cooker with a Terminal Block type A? I've got the instructions and opened the box on the back of the cooker, identified the right screws, but I can't see any way of connecting the 6mm cable to them. They are completely surrounded by black plastic, no holes, and the screws don't come right out. Am I missing something???
A picture would help !
The screws may have metal clamp plates under them, if so the wire should be stripped back 8-10mm and the bare core fitted under the plate, then when the screw tighten the plates compress against the wire.
As for the 'completely' surrounded by black plastic, is that not a snap on cover ? Which once lifted should have knockouts for the cable to feed through to the terminals.
