It did my house with an Octo LNB. It's a messy job and was a right pain at the time.
But I'm SO glad that I did it now. Freesat / Sky in every room without the need for boxes, boosters, splitters etc. I used good quality products, long cable runs so the signal is rock solid.
You're on the right track. Good luck!
Yeah I keep telling myself that it will be worth it once it’s done. My upstairs is easy to do due to the partition walls and also TVs are wall mounted so not far to travel with the cables from loft to the termination point. The lounge is the worst room and needs doing as the freeview aerial feed has NO extra cable left on it and it’s dropping in and out - there is no slack on the cable to pull any more down as it’s all plastered in.
if you have a wall chase open to run the sat cable run some cat 5/6 in at the same time.
Also, is it possible to get extra flexible patch cables for the wall to Freesat box" you could re use the thinner sky supplied cable to make up flyleads
I’m in the process of running cat 6 in house as well - some rooms are done but at the moment I’m trying to work out where is best to put the data cabinet.
Did you use conduit for your sky cable in the wall if so which size ?
