Screw size in Roca flush button?
24 Mar 2017
There's a black screw under the flush buttons that holds them in place.
My plumber has lost it, does anybody know the thread size and length so I can get a new screw instead of buying the full buttons and everything else?
Thanks.
1. Likely to be M4, M5 or M6
2. Use the shank of a drill bit inserted into the hole to get an approximate size.
3. Then if:
3a. 3.4 mm drill fits - M4
3b. 4.3 mm drill fits - M5
3c. 5.2 mm drill fits - M6
Thanks.
Is it one of these screws with those buttons. If so you can have that screw as I've just replaced some buttons and and now have a spare screw!
For reference - diameter 7.5mm, length 25mm (so I'm guessing try an M8 x25mm)
Brilliant! Thanks, will see what I can find. Not sure if it had to be reduced head height, they look quite thin in pictures.
